HP Forum Archive 14
hp42s rom
Message #1 Posted by Paul Andrews on 12 Jan 2005, 4:27 p.m.
I have found several emulators for the HP42S, but each indicates that I need to aquire the ROM code. How does one go about this? I have an HP42S calculator, and would like to run it both in windows and on my palm, but I do not have a clue as to how one goes about dumping the ROM.
Re: hp42s rom
Message #2 Posted by Raymond Del Tondo on 12 Jan 2005, 4:59 p.m.,
in response to message #1 by Paul Andrews
In the links area of the emulator section of this site
should be a link to Christoph Giesselink's page,
(http://privat.swol.de/ChristophGiesselink/)
and there should be a description how to dump the ROM
in a quarter of an hour.
Re: hp42s rom
Message #3 Posted by Erik Ehrling (Sweden) on 13 Jan 2005, 2:08 p.m.,
in response to message #2 by Raymond Del Tondo
Paul - do not hesitate to attempt doing a ROM dump according to Christoph's instructions, you'll be amazed by how simple it is!
Erik
Edited: 13 Jan 2005, 2:09 p.m.
Re: hp42s rom
Message #4 Posted by Jeff O. on 13 Jan 2005, 7:22 a.m.,
Be aware that you need an HP48GX (I think a G+ will also work) to do the dumping. If you have one, dumping the rom is not too difficult (actually kind of fun), although piecing together all of the necessary steps takes a little study. If you need any tips, reply here or send an e-mail.
NO60hzSPAMatFORieeedotMEorg (remove NO SPAM FOR ME and change the at and dot.)
Re: hp42s rom
Message #5 Posted by Thomas Okken on 19 Jan 2005, 9:51 p.m.,
You might also want to take a peek at Free42; it does not require a ROM image, and it runs natively on PalmOS.
Re: hp42s rom
Message #6 Posted by Mike (Stgt) on 21 Jan 2005, 8:27 a.m.,
in response to message #5 by Thomas Okken
Seems I have to mention your Free42 on [link:http://ourworld.compuserve.com/homepages/nutem/pioneer.htm]my site[/link:] as it is the first simulation I see so close to the original. But - not to downgrade your work - if your routines depend on machine specific characteristics and you do need to migrate to a new platform I would advice to use an emulator. Unless the advantages (speed, control, interfaces, and so on) outweight the need to test most routines on the new platform. That is everybody's own decission.
Ciao.....Mike
