Re: HPIL-RS232 interface Message #2 Posted by Hans Brueggemann [GER] on 13 Jan 2005, 1:38 p.m., in response to message #1 by Jon
hi jon, maybe it's not too difficult to fix.
1) OUTP only sends out the program which is specified in the alpha register. OUTP will then send all code from the specified global alpha label to the following END instruction. you should check whether you did a GTO.. after each program you keyed into the calc. if you did not, (i.e., you used STOP at the end of the program), then all programs are "chained" together and cannot be separated by OUTP. if you do a CAT1, you should always see an END between adjacent programs.
2) above said should also fix the second issue. please check the manual for the "GETP" routine, which automates the process of "INP"ing a program. by using "GETP", it is not necessary to do a "TRANSMIT" on HPILCOM. make sure that HPILCOM is not in "DUMB" mode.
plz do also check the documentation of the program for my e-mail address and drop me a line, if you have further questions.
hope, that helps!
cheers,
hans
1234
Edited: 13 Jan 2005, 1:39 p.m.
