Another HP41 MLDL2000 Update Message #1 Posted by Meindert Kuipers on 11 Jan 2005, 2:33 p.m.
Hello all,
It looks like I have bankswitching working! I can sucessfully run the first matrix example of the Advantage ROM, which did not work before I implemented bankswitching. I would like to have some of your suggestions for more tests of the bankswitching mechanism using standard ROM (HEPAX is not supported yet).
There is now one little issue that is bothering me, and that is that the current consumption gets a little too high when I disconnect USB. I am currently trying to fix this with a small hardware modification.
When this is fixed I will prepare the units for the beta testers and quickly after that will start the process of formally offering the production versions of the MLDL2000!
Meindert
