Re: HP 01 calc/ watch setup Message #2 Posted by David Ramsey on 10 Jan 2005, 8:04 p.m., in response to message #1 by Sam
Setting the time and date is amazingly easy.
To set the time: enter
hh:mm:ss, them press the "p" key (rightmost key, third row) if PM.
Press the delta key (middle key, bottom row), then press "T" to set the time.
To set the date: enter
dd/mm/yyyy
...then press delta-D.
