Re: Should it power on anyway? Orange but in the dock? Message #8 Posted by Bill (Smithville, NJ) on 5 Jan 2005, 3:45 p.m., in response to message #7 by Gene
Gene,
0.5 amp should be enough to operate the 620lx. I can't remember if the docking station directly puts the adapter power to the coaxial adapter connector on the 620 or if it's transfering the power through the multi-pin connector. I would try removing the unit from the docking station and pluging the ac adapter directly into the unit.
I would also try the following:
1. Remove the Lithium battery and check to see if show's any effect from the charging. If after plugged in for several hours, the battery voltage is still low, then the battery is probally done for. You'll need a new battery.
2. If battery seems to be accepting the charge, and unit still won't power up, remove both battery and backup battery and let unit set for a day or two. Then reinstall and see if it will power up. I'm assuming that the backup batter is good? But even with a dead or missing backup battery the unit should power up and then give you a message saying "replace backup battery".
3. Last resort - remove main lithium battery. Plug in the adapter and see if it powers up. this "should" be safe, but I'm not 100% sure that it won't damage the unit. That's why I say last resort.
4. If you do Item (3) - and all is well, then check the unit's battery contacts to see if the adapter is apply voltage to them.
Good luck,
Bill
