Re: Does anyone know how to open a Sparcom "Drive 95"? Message #2 Posted by Raymond Del Tondo on 27 Dec 2004, 9:17 a.m., in response to message #1 by db (martinez, ca.)
in most cases it's not a fuse, but the battery.
To open the Drive95, just *carefully* lever out the back pane.
It's only held by flat plastic rivets (?) .
After lifting the pane, you'll see the pcb,
and the battery with it's connectors on the left side of the case.
To remove the battery, you may have to pull out the pcb,
which can be done after pulling the screws under the rubber feet.
The battery may be held in place by a plastic strip.
On 'newer' Drive95 units, the battery is
connected to the pcb with a removeable connector,
on older units the connection is made with tin points.
The suitable relacement battery block is avialable in electronics stores.
Have a nice 2005;-)
Raymond
