Re: 48gx Message #3 Posted by Wayne Brown on 20 Dec 2004, 6:43 p.m., in response to message #1 by bob smith
Are the files on a RAM card? If so, have you checked to see if the write-protect switch is set to the RAM position? If it's set to ROM then you'll get an error when you try to delete (or save) anything to the port(s) on the card.
Also, are the files you're trying to delete actually directories? If so, then you need to delete any files in them before trying to delete the directory itself. (Unless you're using the MetaKernel, of course; its Filer lets you delete directories and their contents at the same time.)
