Re: HP 48 G Message #5 Posted by Tnohl on 15 Dec 2004, 2:11 a.m., in response to message #1 by Peter Torrione
Is it the on/off button, or all the buttons in the column of the on/off button??
If so, is a poping/flexing sensation felt when pushing between the display and the top row of buttons and when pressing on it does the on/off button work right??
If yes, it may be a cold/broken solder on the display twisty hold downs where they are soldered. IF AT ALL POSSIBLE DON"T REMOVE THE DISPLAY...it will not work right ever again if you do, to my knowledge. (prove me wrong)
If you take your calulator apart; I suggest drilling the rivets heads from the top and repacing the rivet with some appropriate screw; "IF" you can remove the beyboard overlay without bending it.
If I had to do over, I would drill the rivets from the top without removing the overlay. But, if you cut the case rivets (the other way of taking it apart) from the inside of the calculator you will loose some rigidity of the calulator.
If it is the actual on/off button by itself, the calculator is a thow away, to my knowledge.
