Re: Bank switched versions... Message #4 Posted by Raymond Del Tondo on 23 Nov 2004, 1:54 a.m., in response to message #3 by Gene
the NoVRAM supports different kinds of bank switching,
the HEPAX, the Advantage ROM, and the 41CX OS are examples.
The aboves use the same principal mechanism.
where the HEPAX is the only one so far using all possible four banks,
and another unique feature, it's auto-configuration.
The planned CCD OS/X will use a compatible mechanism,
thus needing only one ROM ID number.
A bank switched combined Extended IO and Extended IL ROM
is in the pipeline, too, but this will happen after the CCD OS/X...
Raymond
