Re: Transposing a matrix on a 48GX Message #3 Posted by Vieira, Luiz C. (Brazil) on 18 Nov 2004, 12:37 p.m., in response to message #1 by McKinley Lewis
Hi;
adding to Raymond's answer:
1 - you should have either the matrix itself or the name of the variable containing the matrix you want to transpose in stack level 1:
2 - execute TRN comand (like [MTH][MATR][MAKE][TRN])
That would do the trick.
Cheers.
Luiz (Brazil)
