Re: CAS vs Plot Message #2 Posted by Dave Shaffer on 16 Nov 2004, 9:22 a.m., in response to message #1 by Mike (Stgt)
Mike,
It depends on where the square should be on the top term.
Is it (sin(x))^2 (i.e. the entire sin function that is squared) or sin (x^2) (i.e. the argument of the sin function that is squared)?
If it is the first, then this set of trig functions does not even have to be evaluated! It reduces exactly to 1.
Why? Well, you can express tan(x) as sin(x)/cos(x). If you do this, then everything cancels out. In the denominator square root, for instance, you'd get (leaving off the (x) arguments for ease of notation)
sqrt( sin cos (sin/cos) ) = sqrt (sin^2 ) = sin
Similarly, the top of your equation reduces first to
sin^2/sin = sin
Leaving for the final step, sin/sin = 1
