Re: One question: (was: HP-48GX strange corrosion problem) Message #10 Posted by bill platt on 16 Nov 2004, 12:29 p.m., in response to message #9 by Vieira, Luiz C. (Brazil)
Hi Luiz,
I think that even if the corrosion is "external" the electrolyte must needs be below the surface for corrosion to occur, and therefore in the electronics as well, if it is causing corrosion. For, if it were only on the surface, then the paint would be adequate protection from salts etc.
So the question then becomes, will the transient solution cause any harm? My sense is not (provided the batteries are out), as if there is a hydrophyllic corrosive salt in there, it will have been "wet" already, merely from vapor.
Off topic, can you email me? (south american musical instruments)
my first name at plattdesign dot net
Best regards,
Bill
