Re: A Possessed 32sii Message #2 Posted by Vieira, Luiz C. on 13 Nov 2004, 8:41 p.m., in response to message #1 by Ben Salinas
Hi, Ben;
I guess these images might help you somehow; at least it seems to me you did not open your HP32SII so far, did you? I'm almost sure that there is an article about how to open Pioneers, but I did not find it... Sorry.
These are the images:
After opening (Click to enlarge)
After removing the MBoard (Click to enlarge) (Obs: it's necessary to GENTLY, CAREFULY 'untwist' the six metal tabs in order to preserve them for 'twisting' back to place when rebuilding the calculator).
I'd resolder all main IC's and components terminals prior to rebuild the calculator. Sometimes, as you probably know, you do not see a cold soldering in order to identify which terminal do solder, so I always solder them all.
Please, let us know if you succeed or if you need extra advice.
Best regards.
Luiz (Brazil)
Edited: 13 Nov 2004, 8:45 p.m.
