Do you have a manual for either calc? Message #2 Posted by Karl Schneider on 13 Nov 2004, 3:29 a.m., in response to message #1 by LH Chan
are there any operations on hp 32sii that works differetly on a hp 42s?
I question how much you know about the 42S. Its programming paradigm is basically that of the 41C/CV/CX, which means, for example, that labels can be internal or external, "END" statements are the dividers between programs. There might be a problem with your entry f the single-letter labels you carried over from the 32SII program. Single-letter variable names must be delimited by double quotes on the 42S.
Complex numbers are completely different on the 42S, and some function names are probably different.
I would advise that you fully understand the 32SII program, then obtain a manual for the 42S to figure out what its "rules" and conventions are. Blindly copying the listing of one calc's program into another calc using a different paradigm isn't likely to work.
-- KS
