Re: What is the GPIO interface HP 82165A Message #2 Posted by Christoph Klug on 10 Nov 2004, 3:19 a.m., in response to message #1 by Thomas Falk
Dear Thomas,
the HP82165 supports you with an parallel 8bit or 16bit interface port plus some handshake lines.
Most people use the HP82165 for interfacing a parallel Printer (centronics). Unfortunately the HP82166 is AC powered - and therefore not compatible to mobile applications. Furthermore the TRIGGER output control line is not available for this unit, needed for some advanced interface applications.
Therefore I prefer the HP82166 IL-Converter : This is function compatible to the HP82165, supports also the TRIGGER output control line and needs a DC power supply.
Some mobile interface applications like measurement- and datalogger applications developed from me for the HP82166 Il-Converter. More detail about this nice projects you get by searching the subjects I/O-Board and IL2000 System...
Best regards from Germany - Christoph Klug
