Re: Programming HP12C Message #3 Posted by bill platt on 4 Nov 2004, 10:02 a.m., in response to message #1 by Don
Hi Don,
If you started out with the 17bii, and now have a 12c, you will feel like you are going backwards. The 17bii is much more versatile and powerful.
In my opinion, the programming on the 12c is almost useless--you cannot edit a program. If you make a mistake, you have to play silly tricks with GTO jumps, or erase and start over!
With "Let" and "Get", as well as "If" with AND OR XOR etc, you can do a whole lot in the solver on the 17bii.
I had an 11c years ago, and always assumed that the 12c would be similar in programming. Not So! The 12c has a very restricted programming feature, compared to its scientific cousin.
But there are some great things about the 12c---and some here have written some really neat stuff for them--even taken advantage of the TVM solver as a general solver----but in reality this is sort of arcane stuff, and I find that the machine is a relic......but I still own a couple! (They are great for non-programmed straight financial stuff).
Bill
