Re: 7470a plotter gummy wheel question Message #3 Posted by James on 29 Oct 2004, 7:41 p.m., in response to message #1 by andy
From an article I believe I read in HP Digest a long time ago, the tapered roller shape is designed to keep the paper taught and against the guide at one side.
So, I would attempt to maintain/reproduce the shape as much as possible, although the overall diameter may not be critical.
If the flat spot is a result of leaving the roller pressure engaged for a long time, perhaps it will improve a bit after some relaxation and use.
If you find/develop a good replacement, please let us know.
Good luck!
