Re: HP-97 wihtout battery pack? Message #3 Posted by Tony Duell on 27 Oct 2004, 6:51 a.m., in response to message #2 by Mike (Stgt)
It is safe to use the 97 without a battery pack (there is a special circuit intended to prevent the incoming voltage exceeding the Vss rail), but you won't be able to use the printer or card reader (which take too much current for the HP mains adapter).
This circuit is present in all Topcat models, but it only works when the machine is on. For this reason, if you are lucky enough to have an HP95C, do _NOT_ connect it to the adapter without a good battery pack in the machine. You can easily damage the CMOS RAM chips (same as in some Woodstocks IIRC), and maybe other chips. If you kill the ROMs in a 95C you're in big trouble. This is based on reading the schematics for all said machines...
