Re: 19bII no power Message #14 Posted by Vieira, Luiz C. (Brazil) on 27 Oct 2004, 1:32 a.m., in response to message #13 by Forrest
Hi, Forrest;
first of all: never give up an (original) HP device! :-)
Now for the facts: as you see, others like Randy have many good, applicable techniques and suggestions, and I guess that if you followed the ones Randy posted here and the calculator still does not respond, chances are you have a faulty IC. I had in hands an HP41 that had average current drain when the batteries were installed and about a current consumption 5 times higher than average when turnned on. The display was too dimm, and this sympton lead me to check the LCD driver. After replaced, the calculator returned to normal. This sort of maneuvre is not possible in the HP28 because of this:
(Hewlett-Packard Journal, August 1987, p.26)
The hybrid IC's (upper image) contain the LCD drivers: no way to replace any. And the excessive current consumption when the calculator is turned off worries me, because either a faulty electrolytic capacitor or the small IR LED driver (SMD transistor/FET?) may cause it. Even After Randy's precise explanations, I'd at least save it for future experiments. I have one HP28S and I'd like having another, broken one for spare parts... Better yet, having two working units!
As I always say: hope you succeed. Let us know if you want to go ahead and open it.
Best regards.
Luiz (Brazil)
Edited: 27 Oct 2004, 1:51 a.m.
