Re: Connecting HP48G, G+ to Win XP Message #6 Posted by James M. Prange on 22 Oct 2004, 2:58 a.m., in response to message #5 by Ed Look
In fact, it works much better than Conn4x for my 49G+. Now, if
there's a better replacement (like HPCOMM) for the 49G+, that'd be
great.
I hope that you're using the latest version of Conn4x (currently
Version 2.2 Build 2353), which is much improved over the version
on the CD-ROM; it allows "text" transfers (similar to Kermit
"ASCII" transfers) and remote operation of the calculator for a
start.
The latest Conn4x should be available
here,
and the latest HPComm
here.
But note that Conn4x translations differ from Kermit translations
for NUL, literal ", and \. Conn4x may also have a problem with these
characters outside of a quote-delimited character string. For
transfers from the calculator, <CR><LF> pairs are also different
(better).
Note that the MMC/SD card on the 49g+ allows very fast transfers.
If you want Kermit ASCII compatible transfers via the card, see my
programs at http://www.hpcalc.org/details.php?id=6017.
Conn4x also works with the 48G series for Xmodem binary transfers,
and with the addition of the included Xmodem server library to
the calculator, can do the text transfers and the rest as well.
Regards, James
Edited: 22 Oct 2004, 7:23 a.m.
