Couple of mistakes in Finance 1C Message #3 Posted by Gene on 22 Oct 2004, 2:38 p.m., in response to message #1 by Luis
Finance ROM 1c:
1) The 360 calendar mode in DAYS does not calculate the correct number of days between dates when the first date occurs on the 31st of the month and the 2nd date occurs on any day other than the 31st. The result is 1 day less than the correct answer.
2) After initiatization of the MONEY program or after clearing the financial registers (shift E), if I is the variable solved for when N, PV and FV are known (and the PMT is = 0), you cannot solve for another variable until a new value has been stored in some of the registers.
3) When I=0 in the MONEY program, you cannot solve for N, PV, PMT or FV (you get DATA ERROR or an incorrect result).
