Re: Updated HP-41 module list Message #2 Posted by Mike (Stgt) on 19 Oct 2004, 4:45 a.m., in response to message #1 by Matthias
Hi Matthias!
I hope you don't mind if I found at least one little negligibleness. My MCode compilation version 1A displays "-MCODE 1A" in CAT 2, not "MF1A" as shown in your list. The later is the ID of the ROM reported by the Service Module's check function.
BTW, be warned to use the function "AA" of my ROM, IIRC I used it to migrate all HP41 ROMs using an HP-71B as printer. I did that by jumping behind the "correct printer in trace mode"-check of the ZENROM's disassembly routine. W/o the correct module in place "AA" will do nothing useful (MEMORY LOST is quite possible). So be warned or use an HP41-emulator with all appropriate safety measures.
But if you like to impress others, you may run "XX" to just display the "G" of the RAD/GRAD annunciator. <G>
Ciao.....Mike
Sorry, I can't remember if I copied that one or did it on my own:
B800 098 X
B801 018 X
B802 000 NOP
B803 000 NOP
B804 130 LDI
B805 010 CON 16
B806 270 RAMSLCT
B807 130 LDI
B808 0FD CON 253
B809 3F0 PERSLCT
B80A 130 LDI
B80B 200 CON 512
B80C 2F0 WDATA
B80D 2E0 DISOFF
B80E 320 DISTOG
B80F 04E C=0 ALL
B810 2A6 C=-C-1 X
B811 266 C=C-1 X
B812 3FB JNC -01 B811
B813 3E0 RTN
Edited: 19 Oct 2004, 4:46 a.m.
