Voyager Hexadecimal tests Message #1 Posted by bill platt on 8 Oct 2004, 2:43 p.m.
(Thanks to Jordi Hidalgo for the 12c ON-PMT key sequnce info below. I have added what I noticed on the 11c. Have at it--what do you think of this? Try it on the 15c, and 10c and 16c, too, if you can). I don't know if this sequence "messes up" operation, requiring master clear--doesn't seem to).
FASCINATING! try "ON-PMT" simultaneously on the 12c. (put the number three in the x-register first. Then, go f-prefix and hold, and you will see: 0000000o000 )
Now, the ON-PMT also toggles the "BEGIN" annunciator--in an interesting way:
start with machine on, do ON-PMT. Nothing different.
Now, start with the machine off, and do ON-PMT, and you get the "BEGIN" annunciator. now do PMT-ON and the BEGIN goes off, now do it again--no change.now do it the other way, and the "BEGIN" is back.
Actually, do the ON-PMT, then push PMT and hold, and toggle the ON button, and you see the begin come on--and you also see the x-register start toggling through previous values of some sort---
There is also a scrolling or toggling (not sure which) with the ON-PMT or PMT-ON sequence, which brings back older x-register contents--but it does not seem to be R-down--something else entirely!
Are we onto something hackable?
BTW, try the same thing with the 11c, except use ON-Y^x, and you get exactly the same thing as the 12c! (use f-prefix again to see the hex code). Except you cannot get the BEGIN annunciator behavior :-( (the y^x function does its thing).
Actually, there is something strange on the 11c here, too:
Do exactly this:
2
ENT
ENT
ENT
3
Y^X and hold the button
push on and release, leaving your button still depressing the Y^X.
You get 1.000046053
Sometime, I get the "USER" annunciator hfter these sequences on teh 11c, but I am not able to reliably reproduce it----maybe it is because I have a program labelled "D"
Lots of food for thought here.
Bill Platt
Edited: 8 Oct 2004, 2:48 p.m.
