Re: Anyone has remote control software for the 49G+? Message #9 Posted by James M. Prange on 7 Oct 2004, 9:53 p.m., in response to message #5 by Wayne Brown
I'm surprised that JYA wrote that, and that I apparently didn't
notice at the time. I expect that he meant "SIR" instead of
"RedEye".
The 49g+ does have the capability to send in "RedEye" mode to the
82240A and 82240B printers, but, experimentally, the range is
about 5 cm, compared to 1-2 m from a 48 series.
As far as I've been able to determine, the "Serial IR" used on the
48 series isn't available on the 49g+.
The 49g+'s "IrDA" is seriously (and intentionally) crippled to 10
cm on the 49g+ to accomodate the "educational community". Cyrille
wrote that both the transmitter power and the receiver sensitivity
are low. Experimentally, 10 cm does indeed seem to be about the
maximum range that I can get between my 49g+ and IrDA/RS-232
converter.
It might be possible, using ARM programming, to
directly control the IR transmitter and detect light pulses at the
receiver in a "raw" state, but I expect that the extremely short
range would make it rather impractical to use it as a remote
control.
Of course, it might be possible to modify the hardware to increase
the range to the 1 m that's normal for an IrDA device.
Another idea is to build an "IR amplifier" that would be slipped
onto the 49g+.
Regards, James
