Re: HP-12C bug - Not with the HP12Cp Message #3 Posted by Vieira, Luiz C. (Brazil) on 7 Oct 2004, 9:00 a.m., in response to message #2 by James Summers
Hi;
I tried a longer program to check if there was no "reset", but it indeed "clears the display":
f CLEAR FIN
f CLEAR sigma
1
2
0
g GTO 01
The 120 + sequnce is just for setting the loop longer and allow "running" to appear, if so. But nothing happens, it acts as if the calculator is switched to off. If it is left in ths condition, batteries wold "drain out" without any warning. Mine is a Chinese unit, Serial # CN1180xxxx.
I have a Chinese Platinum (CN3290xxxx) and this "bug" does not seem to happen: the "running" message prevails.
Good posted.
Luiz (Brazil)
