Re: HP-97 flex cable replacement Message #3 Posted by Tony Duell on 29 Sept 2004, 4:00 p.m., in response to message #2 by David Smith
What I did in my 97 was to use a piece of 26 way IDC ribbon cable fitted with the normal IDC sockets at each end (like an IDE cable, but only 26 way). Don't forget to feed it through the chassis plate before fitting the second socket :-).
I then soldered 13 pin right-angle headers to the logic and card reader PCBs. You have to fiddle things a bit since you have to use the same row of holes in each socket, IIRC the card reader end (where there's more headroom) is actually a 26 pin header with the bottom row of PCB pins cut off, and I used the row of holes in each connector nearest the top of the calculator in each case.
Works fine, and I can easily remove the logic board or card reader for repairs.
