Re: How do I transfer to ports 1 or 2 using Conn4x? Message #2 Posted by . on 25 Sept 2004, 10:10 p.m., in response to message #1 by Bob Poole
You can't use Conn4x directly. Just put them in HOME, then on the calculator open the filer (left shift, then APPS). Copy the files to the port by hand.
If you look, there are lots of documenation/tutorials for this calculator floating around. See the HP website or google.
