HP Forum Archive 14
For Eric Smith
Message #1 Posted by Klaus on 14 Sept 2004, 7:10 a.m.
Hi Eric,
I canīt get nonpareil o run on my system (Redhat 8). It compiles, but doesnīt run (Writes an "A" to the console and hangs). Nsim doesnīt work,too. (Seems to have a problem reading the microcode). So I ask you: Can you please eMail me a trace of the HP41-startup?
Thank you! Klaus
1234 to delete
nonpareil
Message #2 Posted by Jonathan Purvis (New Zealand) on 14 Sept 2004, 7:44 p.m.,
in response to message #1 by Klaus
I have the same problem with nonpareil. The only thing i can find that causes it is having a version of gtk and/or glib older than the one Eric uses. Upgrading to the latest versions of gtk and glib worked for me, so you could try that (though i'm not sure if there are .rpm files of newer versions available for RedHat 8)
Re: nonpareil
Message #3 Posted by Klaus on 16 Sept 2004, 3:20 p.m.,
in response to message #2 by Jonathan Purvis (New Zealand)
Hello Jonathan!
I just need a description of what the simulator does. Perhaps you can help me. For nsim, it is sufficient to start the program with:
nsim -trace >out.txt
All I need should be in out.txt!
I would be happy if you could help me (Canīt wait to hold a rebuilt HP-41 in my hands)!
Thanks, Klaus
Re: nonpareil
Message #4 Posted by Jonathan Purvis (New Zealand) on 16 Sept 2004, 11:06 p.m.,
in response to message #3 by Klaus
I've emailed you the result of that command. I'm not sure what trouble you were having with the ROM, buti made one in the correct format from hp41cv.obj in Nonpareil by doing:
sed -e 's/:/ /' -e 's/$/ /' < hp41cv.obj > ~/nsim.rom
