HP-33S polar-coordinate bug -- another manifestation Message #1 Posted by Karl Schneider on 31 Aug 2004, 2:28 a.m.
Here is another manifestation of the HP-33S polar-coordinate conversion bug, that was identified by "Steve A" and investigated by me at this link:
Polar Conversion bug in HP-33S
Basically, if a coordinate pair (-0,y) is entered (y not = 0), then the angle of the polar-coordinate conversion is not computed correctly.
This problem is also manifested in the complex-valued natural-logarithm function "CMPLXLN", since:
CMPLXLN (x + i*y) = 0.5*ln (x2 + y2) + i*["atan2" (y, x)]
where "atan2" is the intrinsic function in Fortran and C that gives the correct angle of the polar-coordinate conversion.
It is easy to see that the simplest way to calculate CMPLXLN is to convert the complex-valued input argument into polar coordinates, then take the natural logarithm of the magnitude (radius).
On the 33s, try:
10 ENTER 0 (left shift) CMPLX LN
You will get the correct answer 2.3026 + i*1.5708
Then, try:
10 ENTER 0 +/- (left shift) CMPLX LN
You will get the incorrect answer 2.3026 + i*4.7123 (where 4.7123 = 1.5*pi radians = 270 degrees, which is the angle that "->theta,r" will give).
-- KS
Edited: 31 Aug 2004, 2:30 a.m.
