Re: HP11C self tests Message #3 Posted by Vieira, Luiz C. (Brazil) on 18 Aug 2004, 12:21 a.m., in response to message #1 by Carlos Genders
Hi, Carlos;
can you describe how do you perform the tests and what happens then? I see Cyril describes the [ENTER] needs for pressing twice, but I'd also like to knw about the other tests. Are you having troubles starting them? If so, the best way I think for statarting them is:
Turn the calculator off;
press and hold the key for the test you want ([×], [÷]);
while holding down the 'test defining' key, turn the calculator on;
release the 'test definition' key;
This sequence may also be used for clearing all memory, where the 'test' key is [-] or with [.], to toggle between dot or comma as radix mark.
Hope this helps as well.
Let us know what you get from here, O.K.?
Cheers'.
Luiz (Brazil)
