If you are in Deutschland... Message #12 Posted by Vieira, Luiz C. (Brazil) on 17 Aug 2004, 4:04 a.m., in response to message #1 by Umberto
As your e-mail reads t-online.de, I guess it is in Deutschland... although you may not be there, of course.
Please, consider finding someone closer to you that is able to repair your HP48SX. There are many clever, skilled people in Europe that would give this baby a try. As you mentioned it's been "stuck" for many years, chances are you also have a bad [ON] key with a bad contact (I don't remember if hardware reset turns the calculator ON automaticaly... d8^( and I'm not willing to test.), so it is a waste of good stuff to get rid of it this way. I have an HP48SX working perfectly fine, except for a small oxidation spot in the display that almost hides the right-shift annunciator. Except for this, it is working fine. I'm not sure I'd replace this LCD for this reason, but if my HP48SX does not respond to keyboard, I'd do whatever needed to bring it back to life.
Well, that's just me, sorry! I just do not like knowing about a genuine HP that is not working.
Hope you succeed.
Cheers.
Luiz (Brazil)
