Re: connector of old Floppy drive Message #3 Posted by Tony Duell on 16 Aug 2004, 1:52 p.m., in response to message #1 by Andre Koppel
I think you've mis-interpretted one of my messages. The Mac+ floppy drive is not the same (or compatible) with the drive in any HP disk drive unit to my knowledge. But some of the parts of the drive in the 9114B (and 9153) are believed to be the same as the parts in the Mac+ drive -- the head assembly, stepper motor, motor drive chips, analogue ASIC chip, etc.
Your drive sounds like the one from a 9114A (or 9133, 9122, etc). AFAIK none of the parts of that drive are used in any Mac.
These drives have an interface which is similar to a PC drive interface (and totally different to a Mac drive interface), but they rotate at 600 rpm (PC 3.5" drives rotate at 300 rpm). You therefore can't use a PC drive.
Damage to the upper head is common on these units, alas. The grease on the eject mechanism goes hard/sticky, and the disk holder doesn't latch up properly. The head then catches on the disk when you try to eject it. The only cure is to replace the head carriage and strip, clean and re-lubricate the eject mechanism. Even if you replace the entire drive, I would advise doing the latter unless _you know it's been done recently_. Otherwise you might wreck the new drive's head too.
Incidentally, I've swapped head assemblies on these drives, and found the alignment to be pretty close (checked with a catseye disk). You may not need to do the alignment.
