Re: HP49G+ I/R-Problems Message #2 Posted by James M. Prange on 13 Aug 2004, 3:09 p.m., in response to message #1 by Andre Koppel
The 49g+'s IrDA doesn't work with the "old" 48 series "Serial IR". To transfer between them, you'll have to use your computer as a go-between.
You should be able to print to the 82240B as long as flag -34 is clear (Print via IR), but the range has been drastically reduced. About the best I've been able to get from my 49g+ is 3 inches. Try it really close to the printer's IR window.
Regards, James
