Re: HP 49GX floating comma Message #2 Posted by Richard Garner on 12 Aug 2004, 12:41 p.m., in response to message #1 by Hans Schmellenkamp
If the 49GX is like the 48GX it doesn't have a floating comma. If you set the display mode to FIX 4, when you enter numbers large enough to have commas, it will show the commas after you press ENTER. I liked that feature of the 41C as well. You could tell right away if you made an entry error.
