Re: APPLY command Message #2 Posted by James M. Prange on 13 Aug 2004, 4:21 a.m., in response to message #1 by Matteo Miglioranzi
Hello.
I have a problem with this simple user prog. (hp49g, rom 1.19.6):
1 4
FOR I
I 1 ->LIST
F APPLY
NEXT
Note that I edited that quote to apply preformatted code.
Maybe you want:
%%HP: T(3);
1 4
FOR I
I 1 \->LIST
'F' APPLY
NEXT
Note the ' marks quoting the F.
But I'm really not sure what you want to accomplish. What are the
expected results?
It doesn't work but if you debug it, you get the right answer
(obviously the debug can't be the solution).
Are you using the 49G's built-in debugger, or do you mean
"debugging" it mentally? What do you mean by "doesn't work"? Does
it error out, or does it return unexpected results?
Is it necessary to use WHILE or REPEAT routines or this program
can work also with FOR..NEXT (maybe with some tricks)?
FOR...NEXT seems to me the most obvious method, although I suppose
that I could come up with a program using WHILE...REPEAT...END if
I cared to put some effort into it.
Regards, James
