Re: 41CX PAC Module Check Message #2 Posted by Cyril RABIH on 3 Aug 2004, 3:50 a.m., in response to message #1 by Mark
With rom pac, just type CAT 2 and you'll see a listing of rom available within your CX. If your rom appears that's ok.Press R/S to stop the listing and then use BST and SSt manually to go forward or backward. Once you've reached the ROM tested press ENTER and you'll the listing of the functions available. If you have a x-mem module type EMROOM and you must see 362 (1*xmem) or 600 (2*xmem).
Hope it will help you.
