Re: Your HP35 with bugs: a valuable "fossil" Message #10 Posted by Ronald on 24 July 2004, 3:42 p.m., in response to message #9 by Ronald
Hi John,
As collector I like to hang to this one for some time.
It has some nice other type 1 like characteristics:
Outside:
Silver screws: present,
two piece backing plate (by battery compartment): present,
black two piece shorting clip: present, 1143A0xxxx serial number: present, bump on key 5: present, red dot manual: present, back label "HP35 INSTRUCTIONS": present, battery cover calling for HP03510 battery: not present, gray plastic case is unique to the red dot, allowing the smaller charger to fit snugly: present.
Inside:
Metal LED frame: present, Soldered Circuit board to keyboard assy (not finger connected)not present is finger connected, Red plastic key frame: not present, white plastic, grounding plate inside back cover: present, gold colored metal key membrane: present, circuit board "00035-60010": present, red dot switch: only on the inside.
