Re: HP 86 Questions Message #6 Posted by Tony Duell on 22 July 2004, 6:35 a.m., in response to message #3 by John Nelson
There is an RCA phono socket on the back of the 86 above the HPIB connector. It's not yellow (that convention came in much later), but it is normal RS170-like composite video that you should be able to feed into the composite input (not RF, of course) of a US TV. At least in the 86B (the model with 128K RAM) the video output buffer is designed to drive a 75 Ohm load (that's clear from the schematic) and I have no reason to doubt that also applies to the 86.
I doubt that the 86's video output meets broadcast video standards, but it's close enough to work with all the composite monitors I have.
When you switch on you'll have a fairly long wait (even longer on an 86B) while it checks memory, etc. Then you get a cursor at the top left corner, and can start typing BASIC.
