Calc won't run on batteries Message #1 Posted by David Ramsey on 30 June 2004, 6:34 p.m.
Well, I finally snagged a "red dot". It's easily the most beat-up calc in my collection-- apparently it was stored in a working rock tumbler-- but I knew what it was like when I bid on it.
The calc has obviously been opened and it appears as though a bank of LEDs has been replaced (slight brightness and position differences).
The calc works perfectly on AC but not at all on batteries. The battery contacts are the cleanest, nicest part of the calc.
I will be disassembling the calc to clean and polish it; is there anything I should look for other than obvious broken connections re the not running on batteries thing?
