Re: HP11C ghosting of digits Message #2 Posted by Randy on 22 June 2004, 5:46 p.m., in response to message #1 by Stephen Lay
It's a bad LCD. Will require replacement from a similar date code machine. You're lucky in that it is an early two board model which means you will not need to remove the keyboard for access. The logic module/LCD are seperate and can be removed without cutting plastic rivets.
