Re: HP82162A IL-Printer slow Message #3 Posted by Georg on 21 June 2004, 6:48 a.m., in response to message #2 by Ronald
Hallo Ronald,
thank you very much for your hints.
Yesterday i tried the following and it works.
As the printer sends an error message to the calculator due to the slow motion, I have send "prx" to print only one line without error. I have send this several times to the printer and after a while the printhead moved faster and faster an the error message did not appear any more.
After that I tried "Prreg" and after some tries the head moved still faster.
Today morning the printer still works fine, so I believe, that the problem is solved.
I made a printout of your posting. When the slow motion will appear again in the next weeks, I will post it here.
Thank you once again for your help.
Georg
