Re: solving linear systems on a 48G+ Message #5 Posted by Tizedes Csaba [Hungary] on 17 June 2004, 12:43 p.m., in response to message #1 by Henrik
the problem with your example is the two equation is not independents! Look, this is the simpliest answer:
eq1: 0.5 * x - 12.5 * y = 0
eq2: -2.6 * x + 65 * y = 0
if you multiple eq1 with -5.2, you will get the eq2.
I dont want to digging into the depth of linear algebra, and my english is too poor for the correct answering.
The {0 0} solution is correct - in linear algebra in this case called 'trivial solution'.
Oh, why I can't to speak english...!? :)
Csaba
to delete: 10110
