Re: hp 48 prog and 49G+ Message #6 Posted by Vieira, Luiz C. (Brazil) on 15 June 2004, 12:01 a.m., in response to message #5 by harrington
Hi, Harrington;
as mentioned in this thread (I don't know who, no name, just a dot), if the program is written in User RPL, I mean, if it uses only "regular" functions and commands, you can transfer or use original programs written for the HP48S and/or 48G in an HP49G+. I remember that some minor changes related to empty lists dealing made me change two or three programs that ran in an HP48 and did not run correctly in an HP49G (not G+).
HOWEVER, if the program uses exclusive internal calls, like SYSEVAL with specific addresses or low-level coding (assembly), big chances are that it will not work properly. In some extreme cases, running such programs may cause display and keyboard freezing or even a memory loss. So, it's a good idea trying to find the User RPL equivalent, if available, and recompile it with specific sofware (as mentioned by the unknown colaborator above).
Hope this helps you finding the appropriate program for your needs.
Cheers.
Luiz (Brazil)
