Re: HP 33S Turn off Thousands Separator Message #3 Posted by Vieira, Luiz C. (Brazil) on 13 June 2004, 2:06 a.m., in response to message #1 by Sammy
Hi, Sammy;
I had a look at the User's Manual and found nothing about how to supress the thousands separator in the HP33S. I thought about flag control, like we have in the HP41/42, or using ALL digits, like the STD in the HP48/49 to do that, but I found only fraction control with flags 7,8 and 9.
Other than trying the manual, I tested some possible configurations and (sadly) confirmed that as the HP33S has no "integer" mode for base convertions, the DEC representation for numbers is the same standard representation with thousands separator.
BTW, have you seen how messy is the display when you fill X or Y registers with "2"s? You hardly see any separator between consecutive "2"s.
Sorry not helping that much.
Cheers.
Luiz (Brazil)
