Re: HP-41 doesnt see any plug-in modules Message #2 Posted by Jon on 8 June 2004, 12:13 p.m., in response to message #1 by Miki Mihajlovic
Hi:
Probably you have forced the upper assembly screws, and now there is a faulty contact. You should open it, and look for cracked assembly plastic nut (sorry, I donīt know itīs name in english, but I am sure that you understand).
The voltage is ok.If the pack is thicker, take care, you could damage the other calculator.
Jon
