Re: HP-49g Kernel Message #3 Posted by James M. Prange on 29 May 2004, 6:42 p.m., in response to message #1 by Michel Beaulieu
When i type VER, which give the CAS version, i can read "HP49 CAS by
Parisse, Heiswkanen & Fiechter", and "4.19990729" on the xreg line
Also try the VERSION command.
With a revision 1.18 ROM, the VER command gives me 4.2000031 on level
1, and with a revision 1.19-6 ROM, VER gives me 4.20010912 on level 1,
so I think that your ROM must be an old one.
You ought to upgrade your ROM. Revision 1.18 is the last officially
released by HP; revision 1.19-6 is the latest "beta" revision released
by the developers. Don't let the beta designation put you off; 1.19-6
really is much better than 1.18. It looks to me as if HP management
decided that 1.18 was "good enough", but the developers decided to
continue improvements on their own.
Revision 1.19-6 is available at
http://etud.epita.fr/~avenar_j/hp/49.html. Several different
revisions can be found at http://www.hpcalc.org/hp49/pc/rom/.
A newer CAS is available, but you'll have to compile it into a new ROM
image yourself. Search at
http://groups.google.com/advanced_group_search?group=comp.sys.hp48.
See http://groups.google.com/groups?threadm=6b643d1.0404050522.1c865372%40posting.google.com for example.
You'll need connectivity software. In my opinion, Conn4x (Xmodem
based) is the best; get it from
this
HP page.
But for upgrading the ROM on a 49G, you might need HPComm (Kermit
based), which you can get from
another
HP page.
For manuals, get the 49G "user's guide" and "advanced user's guide";
see http://www.hpcalc.org/search.php?query=guide&hp49=1. It's
also good to get information on the system flags, see
http://www.hpcalc.org/details.php?id=4884, and reserved
variables, see http://www.hpcalc.org/details.php?id=4922.
As Veli-Pekka mentioned, the 49g+ documentation mostly applies to the
49G as well. The main differences from a user's viewpoint are the
different communications I/O ports and the MMC/SD card capabilty on
the 49g+.
Also see
this
HP page.
Note that a lot of the information for the 48 series and even the 28
series still applies to the 49 series.
The comp.sys.hp48 newsgroup can be accessed from
http://groups.google.com/groups?q=comp.sys.hp48, but the archive
is updated only a few times per day, so for active participation it's
better to find a different usenet server.
Of course a lot is available at http://www.hpcalc.org/. Also see
http://page.mi.fu-berlin.de/~raut/ and
http://m.webring.com/hub?ring=hp48.
Regards, James
Edited: 29 May 2004, 6:57 p.m.
