Faulty HP33S Message #1 Posted by Ken Emmens (Auckland, New Zealand) on 22 May 2004, 6:19 a.m.
My ten day old HP33S has, since day one, had the following problems and I was wondering if anyone else has experienced them. The display suddenly dies and is replaced by a line of horizontal dashes, sometimes thick (3 pixels) and other times narrow. The line gradually gets dimmer from the right-hand end and over about a minute it slowly disappears. The line appears randomly anywhere on the screen each time this happens (about every 10 - 15 minutes on average). The keyboard doesn't respond and pressing "C" and "LN" doesn't reset the calculator. New batteries haven't fixed the problem. The other problem is that the calculator sometimes won't turn on. The only thing that gets the calculator working again for both problems is by pressing the reset button on the back. The self-test does not indicate any problem with the calculator.
I'm 99% sure I've got a dud HP33S, but before returning it for service or replacement I would appreciate any suggestions as to possible cause and/or fix. Thanks in advance.
