Re: Programming speed on 48GX Message #2 Posted by Raymond Del Tondo on 18 May 2004, 7:36 p.m., in response to message #1 by Naim
No speed difference, since both port0 and HOME reside in main RAM.
Differences will be there if you store your program in a port>0, or worse, a port>1 . Ports 2 to n are always bankswitched, so code run from there will always be slower.
Port 1 is online (not switched) in most cases. IIRC, there were occasions when even port 1 is hidden, but i'm not sure at the moment.
However, most of my software libraries reside in port 1, and the programs run very fast from there.
Raymond
