HP71B and HP82143A new TTF Message #2 Posted by Vieira, Luiz C. (Brazil) on 16 May 2004, 9:23 p.m., in response to message #1 by Vieira, Luiz C. (Brazil)
Hi, all;
as I mentioned, here are the first two TTF files of the new set.
HP71B Character Set TTF (this one is particularly dedicated to Gordon Dyer d8^)
HP82143A Character Set TTF
Please, let me remind those who have already installed the HP82143A earlier TTF file that this earlier version must be removed prior to install the new one. Also, many characters have new positions so if you have used the earlier 82143A character set TTF with some documents and you added characters with codes from 160 and above, please reorganize the documents so the characters match their new positions, now from 128 and above. The new TTF files are set so in order to fill the gaps between character groups it had before. I'd like you to inspect the new character organization with any font viewer prior to change your documents.
Also, if any PDF has been generated with the earlier 82143A Character Set, please check if it is unchanged. If the Embedded Fonts list was active and the 82143A Character Set was in the list when the documents were created, then these documents will keep their original character set, meaning they need no change.
Please, let me know as you have tested them. And just wait for a while because others, reviewd and brand-new ones, are coming soon...
Cheers.
Edited: 16 May 2004, 9:24 p.m.
