Re: 49G+ Display Message #5 Posted by Helge Gabert on 15 May 2004, 3:58 p.m., in response to message #4 by Veli-Pekka Nousiainen
Thanks, but again, that doesn't work either. One problem is that complex numbers now all convert to vectors. If you have access to a HP 48gx, try it. -52 CF
(2,2) sqrt
Or try
{3 6 2 5 8 9 33333 2587}
With flag -52 cleared "Show many lines", long lists, and complex numbers with std format on stack level 1 "show many lines."
Unfortunately, this doesn't happen on a HP 49g+. You get only one line with a filled arrow on the right. Flag -52 seems to work differently here.
